Shortest Queue is Missing in V2021?
sudharsan_r
sudharsan_r
[ FlexSim 21.0.1 ]
HI,
I am using the latest version V 2021.20.0.1. In this version, i am working on Process flow model.
I couldn't see the "shortest queue" option in the decide block.36014-1610858977682.png
m_rosadini
Hi Sudharsan,
that seems to be the case. I am not sure about the reason of it being removed, buy you could open the code editor for the Decide activity:
and just paste this code (copied from the shortest queue option on a previous version of FlexSim)
Object current = param(1);
treenode activity = param(2);
Token token = param(3);
treenode processFlow = ownerobject(activity);
/**Shortest Queue*/
/**Send to the connector corresponding to the activity with the shortest queue.*/
int curmincontent =  1000000000; // this sets the integer to the largest possible value that an integer can hold.
int connector = 1;
for (int index = 1; index <= nrop(activity); index++) {
    treenode tempactivity = outobject(activity, index);
    int activitycontent = getstat(tempactivity, "Content", STAT_CURRENT, current);
    if (activitycontent < curmincontent) {
        curmincontent = activitycontent;
        connector = index;
return connector ;
sudharsan_r
Hi @marcello.rosadini,
Thanks for the help. Great.
Cheers,
Sudharsan R
Ben_WilsonADSK
Hi @Sudharsan R, was marcello.rosadini's answer helpful? If so, please click the red "Accept" button at the bottom their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
