Setup table for processor
samueltan5550
samueltan5550
Hi, I am struggling with setting up table for the processor. I want to have each of the processor to have the start time (date and time which processor begins with the first part) and end time (date and time when processor finished all 13 parts) in a table in dashboard. Both current and future processor is needed. I am appriciate if u can help me,thanks !!
FelixMoehlmann
I would track the entry and exit time for each item individually. You can then get the overall makespan with a Calculated Table. Then display the data in a chart of your choice (Base Chart Types in dashboard library are charts that need to be linked to a Statistics Collector or Calculated Table manually).
In the attached file only Processor1 is tracked. Change the event to listen to a group of processors (or add additional events) to collect data for multiple processors at the same time.
