Parameterized SQL queries in the Database Connector
sean_tully
sean_tully
Is it possible to parameterize a query in a Database Connector?
For example, say I want to run a SELECT query and have the ability to parameterize something in a WHERE clause, e.g.
SELECT time, user, volume FROM MyDB.Streams WHERE snapshot = $1
...where the parameter $1 could be linked to some variable in the model, such as a Parameter.
By analogy, in python, using pyodbc I can do something like:
import pyodbc
# this is my parameter that will be inserted into the query
snapshot = 123
pyodbc.connect( [INSERT CONNECTION DETAILS HERE] )
cursor = connection.cursor()
query = "SELECT time, user, volume FROM Streams WHERE snapshot = ?"
cursor.execute(query, snapshot)
nguyenthanhnam2310
For more information: SQL Queries. You can take a parameterized SQL with a table in FlexScript
FelixMoehlmann
You can bind parameters to a prepared statement.
sean_tully
Thanks - this is what I was looking for.
So it seems I can use the existing Database Connector to make the connection and I can access the connection through something like:
Database.Connection con = Database.Connection("DBConnector1");
But I need to compose and run the query in FlexScript instead of entering it in the "Import" tab of the Database Connector menu.
nguyenthanhnam2310
You can also find it in the Database.connection.
For example, here is my example code to import the data from the DatabaseConnector1 - new_table and place it into GlobalTable3.
Database.Connection con = Database.Connection("DatabaseConnector1");
con.connect();
//return con.isConnected;
con.query("SELECT * FROM new_table").cloneTo(Table("GlobalTable3"));
con.disconnect();
