Setting default values for user command parameters
lucas_z
lucas_z
[ FlexSim 23.2.1 ]
Is there a way to set default values for the parameters passed into a user command?
The C++ syntaxis doesn't seem to work. I would expect to be able to define it similarly. Am I just missing something trivial?
Thanks in advance!!
For example: I would like to define a function as below. But if I call this with one parameter only, I get the error that I am not passing enough parameters.
mischa_spelt
Hi Lucas,
In the parameters field, you can indicate that the parameter is optional as follows:
(double inputOne[, int inputTwo])
Then in the code, you can check the number of parameters using the parqty function and set the default if necessary:
int inputTwo = (parqty() >= 2) ? param(2) : 42;
where I have used 42 as the default value to distinguish it from the parameter index (2) in this example.
lucas_z
Perfect, thank you Mischa!
