Set trigger for move object based on count items and by time
tall_pauhl
tall_pauhl
[ FlexSim 23.2.2 ]
Hey there, thanks for any responses in advance!
I´ve got a representation of a cafeteria, in which people get served from 11:00 until 13:00. If my plan is that probably 300 meals/ items will be sold, I´d like to produce 200 of them form 7:00 to 11:00 o`clock and the ofter 100 in batches of 25 depending, if they are needed. It´s basically managing minimum waste.
Sending out the first fe 200 isn`t a problem, but I´ve got no clue how to set a trigger for the dynamically produced items. For those to be prodused it basically only need a move option form the warehouse (where the 100 items pre prepared are stored) to the input queue of the processor.
I´d be happy for any advice.
Al the best
Paul
kavika_faleumu
@tall_pauhl, if you have a place where you're storing the 200 meals and distributing them, you can have an Event-Triggered Source that spawns a token in Process Flow. That token can then run through some logic you setup to handle the movement of 25 meals from storage to that distribution area.
