How can input port be open only when queue is empty ?
IrKoZ
IrKoZ
[ FlexSim 24.0.0 ]
Model warehouse.fsm
I can't seem to find a solution for opening the input port from the source to the first queue only when the queue is empty. I have set the trigger on the queue exit port to close the input port and that's how it should be, but I would still like to set the input port to open when all items are taken from the queue.
moehlmann_fe
Getting the timing right for opening/closing ports can sometimes be a bit finicky. If you use the Entry/Exit trigger, a 0s delay (by sending a message and only closing/opening the port in the message trigger) can often help.
model-warehouse-fm.fsm
IrKoZ
thank you very much
