Set Spatial attributes with C++
sergio_v6
sergio_v6
[ FlexSim 21.0.2 ]
Hello.
I'm trying to set the spatial attributes of an object using c++ code, i can access the treenode and change the name, but i don't know how to change these values. how i can do it?
Matthew_Gillespie
The setLocation method is on the ObjectDataType class, so you have to cast the treenode to ObjectDataType:
obj->objectAs(ObjectDataType)->setLocation(0, 0, 0);
Alternatively you can use the setloc() command which just takes a treenode:
setloc(obj, 0, 0, 0);
Matthew Gillespie
FlexSim Software Developer
sergio_v6
It Worked, thank you!
