Sending item on conveyor in process flow
amy_milesB7Q7X
amy_milesB7Q7X
[ FlexSim 21.2.3 ]
I'm having trouble routing pallets on my conveyors. The black pallets should go towards location combiner 11 before continuing down the main conveyor line. If combiner 11 is satisfied, there must be one more pallet on conveyor StraightConveyor_4488_4 and then it should move down the main conveyor toward line 22 (red arrow on pic). In the pic, the pallet should be moving but won't. It seems if I use a decision point, it has to be right before i get to the entry for the conveyor to combiner 11 or it won't turn in. I tried moving this to process flow but I cannot get the send item to do anything although the token does go through the activity (circled below the part that is not working).
Model - https://nestle-my.sharepoint.com/:u:/p/amy_miles_purina/EYXOK5LVG9dOqtZvYftIrP8BZC77UJpyLweE8PmkfIPA...
moehlmann_fe
The issue is that you are (unnecessarily) stopping the items again before the token enters into either of the "Wait for Event" activities. In FlexSim an object needs to be "resumed" as many times as it was stopped before it actually starts going again. So if the token falls through one of the decides and is stopped again, a single resume doesn't suffice.
Simply remove those two custom code activities (the items are still stopped from the first one after the source) and your logic should work.
amy_milesB7Q7X
Thanks Felix, i took those out but it's still not executing the send correctly. I don't think it likes the decision point to be right at the transfer, but that's where the pallet gets held in real life. If i put a decision point on prev conveyor, it works until i need to hold a pallet at the transfer, then it won't go into the line when it's open (at time 1644.23). I don't really think i need the first decision point since process flow should be doing the send but I can't get it to to turn into the line without it. MOdel - https://nestle-my.sharepoint.com/:u:/p/amy_miles_purina/EWvQCN2xt5pCltie0WFJO_UBgOD8a9xAA2-RShv8gHaC...
moehlmann_fe
Sorry, I thought the pallet not contiuing was the only issue. It is indeed the case, that an item can only be redirected to a different conveyor before the leading edge of that item has passed the conveyor transfer.
In this case you could work around it by always sending the item to combiner11 with the previous decision point. The logic can then redirect them to move straight instead, as that transfer is not reached by the time the process flow is triggered.
amy_milesB7Q7X
Thanks Felix! Ryan was able to create a custom code that is much easier than what I was trying to do so it's working now.
