Problem with KINEMATIC_ROTATE
962076751
Message 1 of 8
962076751
[ FlexSim 21.2.1 ]
As you can see in the model attached here, the scissors stopped at about time 9s and kept still to the end. I'm wondering why should this situation happen? Shouldn't the scissors keep rotating till the end?
scissors.fsm
Replies (7)
Message 2 of 8
supportPHJ4A
The angle at which the scissors rotate is determined by the degree_rot value in your model. The value of your degree_rot is 11.24, so the scissors will only rotate to this angle and stop.
Message 3 of 8
962076751
The return value of the addkinematic() func is 8.2s, then why would the whole rotation process stop earlier?
Message 4 of 8
moehlmann_fe
addkinematic() returns the model time at which the kinematic will finish, not the duration.
Message 5 of 8
962076751
Oh, right!
Then i wonder why the model still running as the kinematic already finished?
I set a breakpoint at BasicTE1's "On Finish Offset" trigger, and found that the breakpoint was triggered at the ending time 11.62s. This means the Offset is not sync with kinemaitc?
Message 6 of 8
moehlmann_fe
While addkinematic() returns the finish time, the expected return value of the "On Begin Offset" trigger is in fact the duration of the action.
To sync the "On Offset Finish" event with the end of the kinematic you should return "Math.max(time1, time2) - Model.time" in the begin trigger.
Message 7 of 8
962076751
OK, get it. Thanks a lot, Felix!
Message 8 of 8
ryan_c10
Hi @meng L, were CSN's answer and/or Felix's comments helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
