Message 1 of 9
[ FlexSim 23.1.0 ]
The model source 3 types of item in the two cases.
The one is sent the item from Queue to Processor1,2. The other one is sent the item from Queue to Queue 2,3 (shown below). The Output Flow I setup that is using By Expression.
You can see that Item Type 3 should be left in the Queue in the Processor case because it only 2 output ports. But after I complete this setting in the Processor case, item Type 3 had been sent to the processor.
In the Queue case, the flow is right.
I check my operation in this model, and the setting is right.
Is there any operation wrong in this case, or maybe is a bug in this version?
Attach the model here
Best regards,
Kevin
