Send flowitems to pickup points by item.type
ssrdh
Message 1 of 10
ssrdh
Hi!
I am relatively new to AGV in flexsim. I am working on a model where I have multiple sources with different item.type. In the attached model, I have 2 sources and I have 2 pickup points. Is there a way to use just single source and send item to pickup points by item.type.
AGV_charging_model_flexsim_answers.fsm
Replies (9)
Message 2 of 10
regan_blackett
For your first question, set up your arrival schedule like this:
Notice the 'Type' label is now part of the schedule and the sequence of arrivals is in order by time.
For your second question you would have to change the model layout I bit I think. Rather than sending from the Source directly to the Sinks, send to a two queues that are attached to your two pick up points. Like this:
THen set your Source's Send to Port parameter to:
item.Type
And that will send your items to a port with the same number as your Type label (1 and 2).
Message 3 of 10
ssrdh
hey @Regan Blackett,
I implemented the method you explained above. I am able to send item by type to the different queues. However, the queues are not sending flow items to the pickup points. I have enabled "use transport" for the queue. Am I missing something here?
Message 4 of 10
braydn_t
@Aditya S2
Are you saying you want the queues to move the items into the Control Points, and then have the AGV's load them there instead of the AGV's going to the control points and then loading directly from the queue?
Message 5 of 10
ssrdh
@Braydn T
Either method works for me. In the model I am building I have items sent to the queues by item.Type.
I want the AGV to load those items either from the queue or the control point. But currently the items are on the queue and not being picked up by the AGVs. How do I make sure the AGVs do pickup items from the queue or the control point? Thanks
Message 6 of 10
braydn_t
@Aditya S2 Could you upload your model so we can debug it directly? IF they are connected by port connections correctly, or being referenced correctly in PF, there should not be an issue.
Message 7 of 10
ssrdh
Message 8 of 10
tanner_p
@Aditya S2,
It looks like the connections between Queue1 and Queue2 were made to the wrong control point. The AGV template uses "NextLookForWork" points to determine whether or not there are items to be loaded at a given station. I re-arranged the connections so that the blue connectors between the control point and the queues are connected to a control point that is in the "NextLookForWork" loop.28214-nlfw-connect.png
The model seems to be working now. Feel free to comment back with an update if you were looking for something different.
aditya help.fsm
Message 9 of 10
ethan_h2
How do we designate items only from Queue1 to be on the left control point and only items from queue 2 be on the right cp? I pretty much need to assign a control point to a queue and only that queue. I have 8 queues and 8 CP's(placed directly in front) and want Queue 3 to go to CP3 and then queue 6 to only go to CP6
Message 10 of 10
Ben_WilsonADSK
Hi @Ethan H2,
Do you still need help on this? If so, I suggest posting a brand new question. Posting a new question as a comment way down below an already accepted answer goes against our best practices, and is a great way for your question to get lost.
If you feel the information on this page would help those looking at your own question, include a link back to this question from your new question.
