Selection of set of Racks for the collection of material
rocio_alvarez9R3F7
rocio_alvarez9R3F7
[ FlexSim 24.1.1 ]
In the attached model I have 2 racks where I create small boxes in one of them and larger boxes in the other in a Process Flow of objects for each one (RackLig and RackVol).
In the Process Flow (RecogidaAlmacen) I created the logic to pick up the pieces from the Rack with small pieces. But when I run the model it takes boxes from the Racks with small pieces but also from the Racks with large pieces.
How can I tell you the set of Racks from which I want the box to be extracted?
Thanks in advance!!
RecogePiezaAlmacen_2.fsm
moehlmann_fe
Use an address scheme to differentiate between the racks. For example by using different zone IDs.
rocio_alvarez9R3F7
Thanks for the response.
By applying your advice I have fixed that problem.
But another one appears
In the RackLig Collection Process Flow I only want to extract boxes from the RackLig...then I have put:
but in the Process Flow "RackLig" when I run the model the tokens accumulate in the Find Slot and do not go to the Move Object activity, however the small boxes appear in the RackLig:
I also have another question about the run sub flow of the Process Flow "RackLig". If in the create Object activity I tell it to create 50 and I sign the item label to the token and in the Quantity of the Run Sub Flow I put 50 because I get this:1730105192475.png
Aren't I supposed to run the Sub Flow of 50 and not 3 tokens of 10, 7 and 7 respectively?
I attached the model.
Thanks in advance!!
RecogePiezaAlmacen_3.fsm
moehlmann_fe
Not all racks have slots for all types.
The 10/7/7 tokens are just the ones that couldn't find a slot.
rocio_alvarez9R3F7
Thank you @Felix Möhlmann,
what a mistake!!
Now it does it well.
logan_gold
Hi @Rocio A, was Felix Möhlmann's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
