- Mute
- Permalink
- Report
Hello moehlmann_fe,
I am writing regarding the script you previously provided (which solved my initial issue). I am trying to adjust the import range, but I’ve encountered a problem where the Global Table results do not update.
To clarify, here is what I am trying to do:
Current Status: The script outputs the CSV data to a Global Table named "SequenceImport."
Goal: I changed the parameters in the script from "/test.csv", 1, 1) to "/test.csv", 4, 3). My intention is to import only the values starting from the 4th row and 3rd column of the CSV into the Global Table.
The Issue: Even after modifying the script and resetting the simulation, the Global Table data remains the same as the initial result (from 1, 1). Even if I manually delete the table rows, the output doesn't reflect the new starting position (4, 3).
I have attached the sample data for your reference. Could you please advise on the correct procedure? Please feel free to modify the script if necessary.
Thank you for your help.
Best regards,
