Save model when the model is stop
s1125413
s1125413
Hello FlexSim forum and @FelixMoehlmann
As the title mentions, I'm trying to save the model using FlexScript when the model stops. It works when I execute the script manually, but it crashes to desktop when I place it in the On Model Stop event. I don't understand what causes this issue. Is there any method to solve this problem?
Thank you in advance.
FelixMoehlmann
Saving the model resets the model. Resetting the model executes the On Run Stop code. You have created an infinite loop.
Might I ask what your goal is? Saving the model when it stops seems like a weird functionality to want to implement.
s1125413
Dear @FelixMoehlmann ,
In my primary model, I plan to set the model runtime to about one month. However, when the time is up, the model will stop. I will then import a series of indicators into the database and would like to save the model for future use.
FelixMoehlmann
I guess your best bet would be to run that code just ahead of the stop time. You can use "Model.nextStopTime" to get the stop time if you want a dynamic approach.
joerg_vogel_HsH
You can try to save parts of your model as tree files. And probabaly you can save the statistic as well. It is not as elegant as saving a complete state but you get near as possible to a snapshot a of current model state.
