Running simulation multiple times and save locally
amyhyolee
amyhyolee
[ FlexSim 21.2.4 ]
I want to run the current model 30 times without changing the variables, and I want each result(different result) to be saved as an Excel file locally. I'm trying using the Experimenter.
However, I'm not sure I'm doing it correctly, because this is what I get if I click the View Result button.
How can I configure the model to run 30 times without changing the variables(only change in random distribution) and save the data in personmilestone and personlabel as Excel files?
Jeanette_Fullmer
Hi @Amy ,
Were you able to solve your problem? If so, please add and accept an answer to let others know the solution. Or please respond to the previous comment so that we can continue to help you.
If we don't hear back in the next 3 business days, we'll assume you were able to solve your problem and we'll close this case in our tracker. You can always comment back at any time to reopen your question, or you can contact your local FlexSim distributor for phone or email help.
moehlmann_fe
If you haven't defined any performance measure, then seeing the default PFM with a value of 1 for each replication is normal. Running mutliple replications for one scenario is correct to get different random numbers for the same parameter set.
For exporting tables at the end of an experimenter (or after the experiment has finished and the data is stored in the sqlite file, see the post below.
https://answers.flexsim.com/questions/111161/export-calculated-tables-after-each-replication-in.html
Jeanette_Fullmer
Hi @Amy , was Felix Möhlmann's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
