Run model in background without opening the flexsim
asb_praneeth
asb_praneeth
[ FlexSim 18.0.10 ]
Is it possible to run a flexsim Model in background with out opening the flexsim.
Lets say We have excel file where we will input data then we click a button in excel which will pass the this input data and flexsim model as parameters to command line. Then model will be run in the background and the results will be exported.
I can certainly use a GUI on top of flexsim and display the results after the run is completed. But i just want to know whether the above scenario is possible.
Thanks in Advance,
Praneeth Akondi
mischa_spelt
What you want is possible. The easiest way is using the
/maintenance nogui
switch. For a more extensive answer, you may want to look at this previous question on Answers.
asb_praneeth
Thank You for your reply...!
