Rotated custom model
Zumo
Zumo
[ FlexSim 24.1.1 ]
Hi guys i got a problem,
every time I insert my visual model, the model rotates.Then I have to manually rotate it back via shape factor. I tried multiple formats (step, obj, gltf. etc.) but the result is always the same.
Can you help me with this problem please?
Thank you so much !
Zumo
joerg_vogel_HsH
This is the nature of coordinate systems. You assume that a coordinate component is equal in all systems. It is not. Before you start to design a part, you should test which orientation is imported by your goal system. Then there are lesser steps in an interface to make it look right.
jason_lightfoot_adsk
You have 3 options (at least):
1) Reorient the shape in another 3D tool (some exports also have the option to choose which axis is up : Z or Y).
2) You can put these values in a text file in the same location as the .obj for FlexSim to apply the correct factors as described here. Name the file "Part Studio 1.xbj"
1283
833
1445
.79
1.01
0.5
0.77942
0.69204
1.20048
0
90
0
1
3) Or you can save (and subsequently reload) the the manually corrected visuals (a .t file) using the Visuals GUI's Save option:
Zumo
thank you ^^
