Robot task sequence modification
rothe_ve
Message 1 of 8
rothe_ve
[ FlexSim 18.0.10 ]
a quick question - how to access/edit task sequence of robot? The robot needs to behave in cyclical manner for 4 stations around it....i.e. 1--> 2, 2-->3. 3-->4, move to 1 ... and the cyle continues. Please note that all the 4 locations have parts and capacity available.....
Replies (7)
Message 2 of 8
natalie_white
Hi @Vaibhav R3,
It's hard to know how to help without looking at your model. To receive a more accurate solution, please post your model or a sample model that demonstrates your question.
Proprietary models can be posted as a private question visible only to FlexSim U.S. support staff. You can also contact your local FlexSim distributor for phone or email help.
Message 3 of 8
rothe_ve
Here it is....prac7_1.fsm
Message 4 of 8
julie_weller
Hi @Vaibhav R3! You can do that in 2 ways. You can set the Robot to do Round Robin using the dispatcher window in properties like this:
Another (perhaps better option) is to create a process flow task sequence that has the Robot do that specifically. You can learn more about Task Sequences in this tutorial:
https://docs.flexsim.com/en/23.1/Tutorials/ProcessFlow/Tutorial2TaskSequences/2-1BuildBasicTask/2-1B...
I hope that helps!
Message 5 of 8
rothe_ve
he first suggestion may be incorrect because it affects TE selection and may have nothing to do with the required queue selection. Please correct me if I am mistaken.
Message 6 of 8
julie_weller
Hmm @Vaibhav R3 I looked at it again and I think you're right. Then the only way I could think of to do it would be to create your own process flow
Message 7 of 8
jonah_kendellR47TC
Here's a quick example of a simple process flow for a robot task sequence. You can create any task sequence you want for your robot by following this same pattern: Acquire the Robot resource, create a Task Sequence, execute each part of the task, finish the Task Sequence, release the Robot resource.
RobotTaskSequence.fsm
Message 8 of 8
natalie_white
Hi @Vaibhav R3, was one of Jonah K's or Julie Weller's answers helpful? If so, please click the "Accept" button at the bottom of the one that best answers your question. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
