Robot movement logic
cetim_c
cetim_c
[ FlexSim 22.1.0 ]
I have to implement a robot in my model and I only have the technical specifications. In there, only appears the º/sec of 4 joins, since this robot does not have 6 but 4. I have put these speeds in "edit geometry" but I fell that nothing has been modified becasuse it still has a move time. Is there a way to make the robot move only taking into account those speeds? On the other hand, since it only has 4 axes,I would like it not to move in the ones it does not have and that is why I set 0 deg/seg.
jason_lightfoot_adsk
You will probably need to use the Motion Path method since lowering the joint speeds just created a larger time for the operation (using "Joint Speeds" motion mode).
ryan_c10
Hi @Cetim C, was Jason Lightfoot's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
