Return crane after unloading items
PuiLing
Message 1 of 12
PuiLing
[ FlexSim 23.1.4 ]
how to make the crane return to its original position after unloading the item to the processor.
During the process, the crane will bring the item to processor2 and it will start working with 2 operator. After unloading the item to processor2, the crane should return to its original position.
I have been trying to use process flow to simulate my processor but it does not work.
Traction Motor.fsm
Replies (11)
Message 2 of 12
joerg_vogel_HsH
There is a trigger option on Resource available to let travel a taskexecuter like a crane to a home object or a location.
Message 3 of 12
PuiLing
I tried but it does not work
Message 4 of 12
jason_lightfoot_adsk
You have a delay before you finish the task sequence so the Crane is just waiting for a task to be added to that sequence - it does not evaluate the onresourceavailable since it has not finished the task sequence. When it does finish that sequence it still doesn't return, since there are other task sequences queued and the condition is that there are none.
Message 5 of 12
PuiLing
Is it correct if I do it this way?
Message 6 of 12
Looks better - does it work? I expect you will still have jobs queued on the crane and then the condition will often cause it not to return to the location.
Message 7 of 12
PuiLing
Yeah it does not return to the location.
Do i need to add anything else?
Message 8 of 12
Jeanette_Fullmer
Yes it does work. The issue is that your logic for acquiring the crane was keeping it busy. If you look at the model I shared in your other post you will see this method does work.
batch-processing_2.fsm
Message 9 of 12
PuiLing
Yes i have tried that method and it works.
But i need to continue the process by bring the item back to the processor, is there a way to do that?
Message 10 of 12
Place a breakpoint in the resource available code to detect it firing and step through to see what's happening.
Message 11 of 12
joerg_vogel_HsH
@PuiLing , then you can insert simply a travel to loc task after unloading, then you crane travels to this location before the task sequence ends.
Message 12 of 12
Jeanette_Fullmer
Hi @PuiLing, was one of Jason Lightfoot's or Joerg Vogel's answers helpful? If so, please click the "Accept" button at the bottom of the one that best answers your question. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
