Resources quantity not working
guillaume_v
guillaume_v
[ FlexSim 19.0.0 ]
I have a problem with my model: I want to acquire x2 resources called "AMR" but on my process flow there's only 1 used.
allister_wilson
I can't see anything wrong in the screenshot you provided, it shows that 1 token is currently using the resource, which is expected regardless of the acquired quantity.
You can see what was actually acquired on the token itself.
Assuming it is indeed not acquiring the correct quantity, could you upload your model so we can take a closer look?
guillaume_v
@Allister Wilson
On the Activity Properties on the right I put Quantity as "2.00"
Shouldn't the green number next to the Resource AMR be "2" as 1 token passed this stage?
allister_wilson
From my previous comment :
You only have 1 token using the AMR resource, so it shows 1.
For instance, in the below image, 1 token has acquired 2 objects from the Sources resource :
If your model is behaving differently, please upload it so we can take a closer look.
guillaume_v
Understood, thanks @Allister Wilson
