Required output item is not seen on exit trigger
sri_vikas_k
sri_vikas_k
[ FlexSim 23.0.2 ]
Hi @Joerg Vogel
I have tried the solution you have suggested yesterday.
I have imported your 3D models and copy pasted the items which i needed and made a new flow item, So that on providing the ON Exit trigger I thought to change the visual so that I can achieve that. But the visual is not seen in the trigger box.
Logistics Handling_autosave.fsm
joerg_vogel_HsH
I do not change a visual shape in a trigger. The attached files are shapes. I make new flowitems in Flow Item Bin.
  • In Flow Item Bin I make copy of a pallet by an icon of the toolbar.
  • I exchange the Shape by browsed file.
  • I adjust shapefactors and item size attributes.
  • Optional: I write my own stacking algorithm to place items on shelves. Or I set visibility of drawn surrogate objects and hide stored items.
  • In a model I create items of the flow item bin and then I choose my new item type.
If you read the thread of referenced shapes and also linked threads, you find models using these shapes as flowitems. You can make a user library from the moving rack items in those models and save the user library then to be used in a different model again.
joerg_vogel_HsH
jason_lightfootVL7B4
Note that if you want shapes to be embedded in a user library you'll need to manually add a packedmedia node above the relevant objects in the tree.
andrew_o2
Hi @Sri_vikas K, was Joerg Vogel's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
