I am not able to upload the autocad file
ssahay7FQ8M
ssahay7FQ8M
[ FlexSim 22.1.1 ]
kavika_faleumu
Hey @Somya S, thanks for the question! Could you give me more details on the problem you're running into? Do you get an error when trying to click "OK"? Does it import but then not show anything? Are you following the tutorial in the documentation?
ssahay7FQ8M
Hey Kavika,
I don't get any errors. It just doesn't show up. It would be great if we can set up zoom for 10 mins. I have been trying since yesterday.
kavika_faleumu
Ok I'll send you a Zoom invite, we can talk about it. Please check your email for a link
kavika_faleumu
Here's a summary of the things we troubleshot on the Zoom call for anyone interested in finding a solution to a similar problem. This is the documentation page for importing CAD Drawings for reference.
Ensure nothing else has the file open
When trying to upload the file as a background, there would be no visible layers in the "Layers" tab. This indicates the file wasn't uploaded properly. To fix this problem we saved the .dwg in a different location (i.e. the FlexSim Projects folder) and closed the CAD software. After this we tried to upload the file from the new file location and the layers loaded in properly.
Center the project around the origin
In the CAD software, the model was several thousand units away from the origin. You can see these coordinates at the bottom of the CAD program. So, you can either center the model around the origin in the CAD software or you can edit the Position X, Y variables in the Model Background Properties in FlexSim (under where you add the File Path for your .dwg file).
[Here's what the Model Background Properties window looks like. You can see a place to put the File Path and the X, Y, Z coordinates below with a "Scale to Model Units" in case you need to rescale your model]
The Model looks wrong after uploading (e.g. it's missing layers)
Even after importing and centering a model, it may look off. We suggest "cleaning" and preparing the file before attempting to upload it. You can find steps on how to prepare your file in the docs at Preparing Floor Plan Files Before Importing.
If you continue to have problems, let us know!
preetdesai
I ran into similar issue and the solution worked great! Thank you!
