Replace FlexSim rack with custom rack
glenys_c
glenys_c
[ FlexSim 20.2.1 ]
Hello! I am currently trying to import a custom drawn rack into FlexSim. I would like for this rack to function the same way as the racks in FlexSim do as ultimately I hope that the ASRS in FlexSim would be able to load and unload items onto this custom rack. Alternations to the dimensions can be made, but I do hope that it retains its shape. The image that I have attached below is what I have in mind: the ASRS will load and unload from the custom rack, the flow items are placed into the slots of the rack.
I have attached a step file of my 3D drawing for better reference. Thank you!
CustomRack_STP..zip
jason_lightfoot_adsk
In the attached model I've added the shape to the drawsurrogate of the rack.
Because there's no undo on the rack dimension editor (and I keep losing the selection while editing) I've created the GlobalTable1 containing the rack dimensions, and apply that using this script:
configureRackFromTable(Model.find("Rack1"),reftable("GlobalTable1"));
The result looks like this with the rack shown - for alignment. Once aligned you can choose Wireframe as the rack visualization.
Clicking on the shape will give you all the normal rack properties due to it being a drawsurrogate object.
RackShape.fsm
jon_abbott
This is very useful, @Jason Lightfoot! Thank you!
