These are two different travel tasks to two (potentially) different destinations.
Number 2 in your diagram happens first, and makes the AGV stop at the item's destination control point and then unload the item to the destination.
Once the AGV has unloaded the item, it is going to check if it should stay in unload mode (Should I Stay in Unload Mode?). It will stay in unload mode if the AGV has an addional item to unload (the AGV has multi-item capacity), and the user has set the process flow variable UnloadToEmpty variable to 1, meaning once the AGV starts unloading, it should unload completely before loading again.
In this case, it will figure out which of its next loaded items it should unload next (Query Best Unload Item), travel to the point where that next item should be unloaded (Travel to Unload Point) and jump back into the main loop, which will subsequently cause the item to be unloaded.
In some situations, the destination for Travel to Unload Point will be the same as the destination for Travel to Stop, but in many cases it will not, so Travel to Unload Point is NOT a redundant travel task. Travel to Stop travels to a first item's unload location, and Travel to Unload Point travels to a second item's unload location.
