Repeat Random Streams giving different results
thomas_jr
Message 1 of 8
thomas_jr
[ FlexSim 20.0.2 ]
Hi folks
I have noticed that the tokens in the processflow sometimes change ID between runs despite having Repeat Random Streams active, which makes it very difficult to identify bugs.
Is there something hidden in FlexSim that I should be aware of that may cause this kind of behaviour?
Best regards
Thomas
Replies (7)
Message 2 of 8
joerg_vogel_HsH
Perhaps you have activated "Initialize random streams based on system time" in
File > Global Preferences > Environment28075-initialize-random-stream-system-time.png
Message 3 of 8
thomas_jr
The field is unchecked in my FlexSim, but thanks for the answer!
Good to know for potential future applications.
Message 4 of 8
tanner_p
Hi @Thomas JR,
Do you have a model you could upload with this issue that we could take a look at? And are you seeing this issue in Experimenter or just in normal test runs of the model?
Message 5 of 8
thomas_jr
Hi @tanner.p
Unfortunately not. I'm working on a large healthcare model that contains sensitive data and other elements.
The issue appears in normal test runs. I've yet to dive into the Experimenter.
Message 6 of 8
Matthew_Gillespie
This page in the user manual goes over some of the things that can cause you model to not be repeatable:
https://docs.flexsim.com/en/20.0/BestPractices/ModelRepeatability/
Matthew Gillespie
FlexSim Software Developer
Message 7 of 8
benjamin_w2
Hi @Thomas JR, Was Matthew's comment helpful? Do you still need help with this?
Message 8 of 8
thomas_jr
Hi @Benjamin W2
Sorry, I did take a look at the section described, but I have yet to test if it resolves my problem.
