Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Reading Spatial Information from .dwg Files
nicolas_obeso
nicolas_obeso
My work with FlexSim frequently requires me to draw out paths for vehicles that match what my colleagues come up with using Vehicle Tracking. I have been tracing over the .dwg up until now and I am interested in automating the process. Is there a way in FlexSim to read spatial data from a drawing set as a model background? Thank you.
FelixMoehlmann
You can read data from a .dwg file with the Interop module installed. I suggest you take a look at the example models in the linked post. They explain the possibilties quite well.
https://forums.autodesk.com/t5/flexsim-knowledge-base/autodesk-interop-module-example-models/ta-p/13...
