- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Is there a quick way to change 1 or more Processors to BasicFRs?
The new class property from the 25.1 release does not seem to support BasicFR as a possible class. So no, there is no 'quick' way to do this. What properties would need to be carried over from the processors? Do they have port-connections, labels or triggers? Do they act as instance objects for an Object Process Flow?
I would need to carry over labels, triggers, name, location, rotation, and size. They do not have an object process flow. The intention is to use BasicFR and create an object process flow. The default Processor logic is no longer sufficient for the model.
The only tricky bit are the triggers. The simplest way would probably be to add a BasicFR to the model and give it (empty) triggers that are set on any of the processors. You can then create copies of that BasicFR and copy over the other properties from the processor. Note that there are some processor triggers that do not exist on the BasicFR such as OnProcessFinish.
