Question (plane with parameters)
samuel_patarroyodiaz
Hello everyone,
Iam trying to use the parameter in my model to control how many lines (planes) ans operators with a dispacher option  i'll need it, but some happend with i use 2 planes for the processor2 (not call the operator2) and i not sure haw can i fix it.
The operator 1 works great, but not for the operator2.
Attached model.
Thank you .
ABajpaiWMKNX
Hi, i have an unrelated question. How did you attach the fsm file to this query? I have been trying to attach the .fsm file to my question but it does not allow me to do so.
Hi, drag and drop in this option.
 you'll see de model atached (exemple)
moehlmann_fe
When the plane gets copied, the connections between objects within the plane get copied as well. Connections of the plane itself to other objects (Queue3 and Queue4) get recreated as well in the OnSet code of the parameter. However, connections of objects inside the plane to objects outside the plane (the processor-dispatcher connections) to not get copied over). Processor1 isn't actually using the operator for anything, so the missing connections is not an issue there.
You either have to adjust the OnSet code to recreate those connections as well, based on objects names.
Or, instead of using centerport-connections, you just use a fixed reference to the respective dispatcher in the processor properties.
Thankyou @moehlmann_fe , now works.
