Question on how to change rotation of an item leaving a processor
jakub_hertmanowski
Observer Observer
jakub_hertmanowski
Observer
Observer
Hello!
I'm fairly new to FlexSim and I'm making my first semi-advanced simulation. I want to have a processor turn metal coils into rollers. Graphic side works perfectly well, but now I'm trying to simulate defects. I've wrote some code which preety much does what i expected:
Object item = param(1);
if (item)
double probability = 0.50;
double r = uniform(0,1);
if (r < probability)
item.color = Color(255, 0, 0);
item.size = Vec3(2, 1, 1);
It changes the color and size according to my probability, but I also want to change item's rotation. In the documentation i found the setRotation() method but using  item.setRotation(45, 45, 0); doesnt seem to do anything. Is there something I'm doing wrong? Is there another approach to this problem?
Thanks in advance for any advice!
FelixMoehlmann
Does the item enter a conveyor after leaving the processor? Because that will reset the rotation (or rather apply whatever orientation is set in the Entry Transfer). You would have to set a label and use the "Movement" options in the triggers of Decision Points or Photo Eyes to change the rotation on the conveyor.
jakub_hertmanowski
Observer
Observer
Thank you very much! That was indeed the case. Since I was outputting directly onto a conveyor, the rotation was being reset — which makes sense now that you mentioned it. It works perfectly with Decision Points though!
