Question about Wait for Event
selvantamil674
selvantamil674
[ FlexSim 23.1.1 ]
Is it possible to give the if condition for Wait for event activity, I have a global table it will increment the value, once the value changes to 1 wait for event activity has to release the token to next activity. if its 0 or other integer it has to hold the token
jason_lightfoot_adsk
To do this your datatype in the table would need to be tracked variable.
Rather than listen to a central table I'd recommend listening to objects and their events, or coordinating through lists as these are likely to be easier to implement, track and debug.
selvantamil674
How to do that with the tracked variable
You change the datatype of the column or cell to tracked variable. Then you need to set the value using Table.cell().value=
I don't see the benefit over the other synchronisation methods - an object approach I find is always better than centralised systems.
WaitForTableCellValueChange.fsm
