question about AGV rotation
wangxu_zp
Message 1 of 13
wangxu_zp
[ FlexSim 22.2.0 ]
How can the AGV keep the direction of the body unchanged when it is driving along the AGNetwork, when it is turning or changing lanes and so on?
Replies (12)
Message 2 of 13
joerg_vogel_HsH
Message 3 of 13
wangxu_zp
I use this method in version 2022, when I script the updatelocations(current) and save, the model is directly closed. Looking forward to your new reply, thank you very much.
我在2022版本中使用这个方法,当我编写updatelocations(当前)脚本并保存时,模型直接关闭。期待您的新回复,非常感谢。
Message 4 of 13
joerg_vogel_HsH
@wangxu_zp, please attach a Model, which behaves as you have described it. Thanks!
Message 5 of 13
wangxu_zp
Message 6 of 13
FelixMoehlmann
I don't remember in which version this change was made but updatelocations() now executes the PreDraw trigger of the respective object. Putting this command inside said trigger thus creates an infinite loop that crashes FlexSim.
The logic should also work without calling updatelocations(). At worst there is going to be a one frame offset between the actual location and the position where the shape is drawn.
Message 7 of 13
jason_lightfoot_adsk
In version 23 you can just uncheck the rotate checkbox on the task executer properties:
Message 8 of 13
wangxu_zp
1689552506380.pngWhen AGV Path is used, the rotation button cannot be selected
Message 9 of 13
joerg_vogel_HsH
@wangxu_zp , is it a picture of Version 23.0 and later or earlier Version like 22.2? That is important, because Jason’s comment mentioned explicitly Version 23.0 as having this new feature!
Message 10 of 13
wangxu_zp
I'm using the Version 2022
Message 11 of 13
Yes, but since this forum is a resource for all it's worth pointing out the current method for users who need it, and also to encourage you to use the supported versions.
Message 12 of 13
wangxu_zp
Thank you for your approach and guidance
Message 13 of 13
julie_weller
Hi @wangxu_zp, was Joerg Vogel's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
