Query list with array label
timdaiYLHWA
timdaiYLHWA
Community Visitor
Community Visitor
Hi
I have array label call Machine in list. I want get value from list where label "a" match Machine. How can I modify it.
moehlmann_fe
It works if you add the variable directly into the query string. I don't know why the $-syntax doesn't work in this case.
...WHERE '" + a + "' IN Machine
joerg_vogel_HsH
a is a command. This can cause effects when the interpreter is building a query string. Typically nobody should use restricted names as local variable names. Other single character commands are i and c.
