Pull only elements from list that are in label array
olavnarjord
olavnarjord
[ FlexSim 22.1.4 ]
I am having problems filtering out the correct elements from a list. I have a pickloop that has totes on it with specific destinations. I am routing these based on the distance along conveyor, and I have a script that works for the distance. The trouble I'm having is that I only want to have the destinations that are stored in the tote to be "pullable" if that makes sense.
On each tote I have a label array like this:
And a list with the following entries:
1681071838619.pngHere is an illustration of the loop:
The logic is that I only want the decision points in "dests" to be applicable for pulling. So in this specific situation, "/DP3" is the closest one, but it's not on the list. Thus, it should choose /DP4 because that's in "dests", and is the closest one.
I have tried to make this work for a few hours and I'd appreciate any help.
pull_based_on_approved_destinations.fsm
jason_lightfoot_adsk
Change the puller to be the token so that you can reference the tote in a WHERE clause, and the still access the dp in the time_to_dp expression.
WHERE value IN puller.tote.dests
olavnarjord
Thank you!
I got it to work with this query:
WHERE value IN puller.tote.dests ORDER BY time_to_dp ASC
And by slightly changing the conveyor time script to this:
Variant value = param(1);
Variant puller = param(2);
treenode entry = param(3);
double pushTime = param(4);
Object dp = puller.dp;
double convtime = Conveyor.estimateConveyTime(dp, 0, value, 0, 1, CONV_ESTIMATE_STANDARD_SPEEDS);
return /**/convtime/**direct*/;
I guess I'll have to use the puller keyword when working with lists.
Yes sorry for the token reference - a late night mistake.
