Pull from list based on quantity
lambert
lambert
[ FlexSim 22.1.0 ]
Hi, this might be a very simple question but I'm stuck. Hopefully someone can help me?
How can I pull from a list two pallets, only when there are two in the list ready for the same arc and in the same partition?
In the example below, I would like to pull EuroPallet and EuroPallet3 from Partition 1, because there are already two ready for the same arc (5).
The same way, pull EuroPallet and EuroPallet4 from partition 2.
I am using process flow for push/pull.
jason_lightfoot_adsk
One way would be to query the list with the GROUP BY clause and the COUNT() aggregator and use that to build an array on the token for the subsequent pull. To use the table query, the list should be global.
