Processing time experimenter
schandrasekar
Message 1 of 8
schandrasekar
[ FlexSim 22.2.2 ]
Capture.PNGHi,
The attached model has 6 processors fed by an AGV. Processor 1&2 has one processing time, the remaining 4 other processor has cycle time based on the case. Can someone help me to build an experimenter to run different scenarios for the cycle times mentioned below and identify the cycle time which produces maximum output in the sink "F4 RH Output" and F4 LH Output" Thanks in advance!
Replies (7)
Message 2 of 8
Jeanette_Fullmer
Hello @Santhosh C,
Can you upload you model to our file share site that is linked and mentioned above?
Message 3 of 8
schandrasekar
Hi Jeanette. Just uploaded the file
Message 4 of 8
Jeanette_Fullmer
Hello @Santhosh C,
I added a model parameter for each of your cycle times.
You will want to go into your model and replace the times with the reference to the parameter like the following.
Model.parameters.F4RHRN1_4
I added the process time into the experimenter for processor 1 and 2.
Model Link
Message 5 of 8
schandrasekar
The file name is "Experimenter_Trial_091322"
Message 6 of 8
Jacob_White
Hi @Santhosh C, was Jeanette F's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
Message 7 of 8
schandrasekar
Sorry. Just accepted the answer and rewarded her:)
Message 8 of 8
schandrasekar
Thank you very much Jeanette!! It works perfectly.
