ProcessFlow: How can I separate an Array from an Token
david_draganov
david_draganov
[ FlexSim 22.2.0 ]
I'm creating a simulation of a warehouse. I need to separate a label array (the location of the product on the 3D model) from 1 token to multiple tokens with only the location for then the task executer pick it up and move that objet.
jason_lightfootVL7B4
There are many examples of this here on this forum - students are encouraged to research before asking fresh questions here.
You simply use a RunSubflow activity using the array length as the number of tokens to create and labelling each with the product using the 'creationRank' as the index of your product array.
joerg_vogel_HsH
In a Case where you don’t need an unchanged array anymore, you can do this by array methods returning a single array element from end or beginning of your array, while this element get removed from the array.
Please look for it in API reference manual about Array datatypes.
andrew_o2
Hi @David Draganov, was Jason Lightfoot's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
