Process Flow Error: invalid task
bryanastra
bryanastra
[ FlexSim 23.0.10 ]
Operator Process Flow.fsmThe load operation from the 3rd Process Flow has an invalid task sequence. I get the following:
Any ideas how to fix this? I would like the operators to pick up those boxes and continue the flow.
natalie_white
This indicates an error in the "Load" activity in your process flow. Your Executer /Task Sequence and Item fields are invalid. If you look at the token, you'll notice that it has a label "Item," but you are referencing "item" with a lowercase i. This is your first error. The second error is that the child token within the subflow doesn't have a label "resource" at all (only the parent token does). To change this, go to the Run Sub Flow activity and check "Copy Labels to Children on Create."
DiegoAvila1
Hi Bryan,
That task error occurred because in the Load and Unload activity you had referencing to "item", where it shoul be with upercase "I".
A recommendation to avoid this kind of mistakes is opening the Token Label and select the one you might use.
bryanastra
Ty, problem solved!
