Problems with AGV rotation
supportPHJ4A
supportPHJ4A
[ FlexSim 22.2.0 ]
Hello everyone:
I encountered a problem when I used the AGV rotation function newly added in version 2022.2. When I selected Accumulation as Default Accumulation, and set the AGV rotation threshold to 90°, the entire AGV network would form a similar at intersection point The logic of the control point,that iswhen the previous car is performing the rotation, the following car will wait until it is completed.Is this a deliberate design or a BUG?
Thanks for your guidance.
(Due to some problems with the model upload, I will upload the problem model later if needed)
supportPHJ4A
This is an illustration of the problem model; normally TaskExecuter3 has left the location of TaskExecuter1, where TaskExecuter1 should execute the rotating task, but it doesn't, only when TaskExecuter3 leaves the intersection, TaskExecuter1 starts executing the rotation.
anthony_johnsonT83CM
We have found and fixed a bug associated with the new rotation feature in conjunction with accumulation. This fix will be included in the next bug fix release, and I think this should fix your issue.
Jeanette_Fullmer
Hi @CSN, was anthony.johnson's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always unaccept and comment back to reopen your question.
