Problems importing 3D object
idoia_a
idoia_a
[ FlexSim (other) ]
I downloaded a 3D object from 3D warehouse, I want to use it to customize the visual shape a forklift. The problem is that when I import it the forklift is not replaced, both, the new object and the forklift are shown. In addition, when I run the model, the forklift is scaled to the new object's size, both are shown overlapped.
Is there something that needs to be changed in properties in order to avoid this? I am working with Flexsim 17.2.4., I attach pictures.
Idoia
joerg_vogel_HsH
The forklift (transporter) doesn't consist of a single shape. It is an animation structure of several objects. Please open the general tab of the transporter properties window.
Then you activate the Edit button in the field Visuals/Animation. The Animation creator opens. At the bottom you find a structure with eye icons as nodes.
You can deactivate the visibility of each node by clicking on the eyes. Then only the replaced / imported shape stays visible.
In my pictures is this the side skirt of an conveyor.
idoia_a
Thank you, it worked!
