Problem with preemptions
oscar_c13
Message 1 of 11
oscar_c13
[ FlexSim 22.1.2 ]
Hello everybody,
I have a problem with mi moden and I tried to replicate it with this example.
While an activity that lasts 60 seconds is being executed (being in fr1), every 40 seconds the operators must go to FR2 and stay 5 seconds. When the operator finis the activity that he is doing in fr1 he has to go to fr3 but he have to keep in mind that every 40 secons he still has to go to fr2. fr2 has to go a totl of 2 times. I made a tracked variable so that it looks at the times it has already fone fr2 and make the save context with differente values. It gives me an error and it doesn´t work either.
Any ideas?
preempt.fsm
Replies (10)
Message 2 of 11
jason_lightfootVL7B4
Please take a look at this post where the use of task sequences and milestone is outlined. This is a better way to preempt that the token context saving method you have tried.
This is the example model:
interruptionv2-jl3.fsm
Message 3 of 11
oscar_c13
Thanks for your answer
The problem with the attached model in your answer is that it is not doing exactly what is requested. The 10 seconds are counted all the time, and not from the moment the operator arrives at queue2. Another problem is that it is an infinite loop, it does not stop when the operator has been in queue2 for 40 seconds.
On the other hand, I didn´t understand the use of milestones and how they can help.
Message 4 of 11
It was from another question (linked) so I didn't expect it to have the same parameters as yours.
It isn't in an infinite loop - the 'core system' task completes at 479 seconds, having been preempted away for the other 439 seconds.
It's an example of how to preempt a task executer using the best method. If you had any number of core tasks at different locations , the use of the milestone allows you to preempt to a different location and not worry about knowing where the operator needs to return to complete a task - the milestone does it for you. Change the timing and see how it works.
Message 5 of 11
oscar_c13
Sorry really, but I don´t understand how your model works. What makes it stop at that time?
Message 6 of 11
oscar_c13
I tried to do with the milestone but it does not work properly.
preempt.fsm
Message 7 of 11
Here's your scenario:
interruptions_jl4.fsm
Message 8 of 11
oscar_c13
Ok thanks, I understood it. Only 2 clarifications.
1. How can I make that the source that creates a token every 40 seconds start at a certain time? That is, in my real model I don´t want it to run every 40 seconds from the beginning, but I want it to run after a sequence of previous steps. It is possible to activate and deactivate that source from a code editor?
2. Why the first sub flow run for 78 seconds and not 60?
Message 9 of 11
1. Call the Preempting FR2 as a subflow from something else that is generating events with the timing you want.
2. You preempt the CoreTask for about 18 seconds so it takes longer than the 60 second delay.
Message 10 of 11
oscar_c13
Sorry Sir, but How can I make it stop when he has already gone twice to fr2? Is it possible to disable the token creation every 40 seconds?
Message 11 of 11
Sorry I missed that the FR2 visits are only twice.interruptions_jl5.fsm
