Priority to the network node path
diweashish94
Message 1 of 26
diweashish94
[ FlexSim 24.1.0 ]
Hi Team,
In the model attached I want to give the priority for the path1. So if there is any AGV moving on path one, the other truck on path2, path3 and path4 should wait.
I tried this with the help of traffic controller using Untimed Traffic Modes. But was not able to control the movement. I tried using multiple traffic controllers but still was not able to give the priority to path1.NetworkNode_MutipleTC_1.fsm
So please help me with this or suggest some alternate option to give priority to the path.
Thank you
NetworkNode_Nonpassing_1.fsm
@Jason Lightfoot @Felix Möhlmann
Replies (25)
Message 2 of 26
moehlmann_fe
Can the trucks on the horizontal paths move across the intersection in parallel or are those paths also limited to only allow one vehicle in the intersection at a time (like the traffic modes are currently set up)?
Message 3 of 26
diweashish94
Hi @Felix Möhlmann
Trucks can move in parallel in the intersection.
Message 4 of 26
moehlmann_fe
If the trucks can move in parallel then it's essentially a question of enforcing a FIFO rule for entering the intersection, so any trucks wait after the AGV has arrived at the intersection.
My idea would be to enforce this through a zone in Process Flow. The zone has a subset called "Limit". It has a calculation called "TotalWeight" that sums up the "Weight" labels of all tokens in the subset. A subset constraints limits this sum to 1. A token belonging to the AGV has a value of 3, those belonging to trucks of 1. This means that while up to 3 trucks can enter in parallel, the AGV token must be alone in the zone in order to be allowed to enter.
Using the "Enforce Queue Order" option of the zone, whenever an AGV token wants to enter the zone, any subsequent tokens will wait for it.
Note that in order to allow the easy of the Event-Triggered Source and the Wait for Event activity, I switched some connection ranks of the paths, so driving into the intersection is always the first path from a node ("To Edge" = 1 in those activities).
networknode-nonpassing-1_1.fsm
Message 5 of 26
diweashish94
Thank you for the solution.
Is it possible to vary/change the speed of truck or Agv inside the intersection.
Message 6 of 26
moehlmann_fe
You can use the traffic control object to limit the speed depending on the number of travelers within the area.
You can also set the maximum speed as part of the Process Flow (token.traveler.setProperty("MaxSpeed", value)), but that will only take effect if the traveler is stopped, then the speed is changed and then the traveler is resumed.
Message 7 of 26
diweashish94
Can the connection type of node be changed to either Passing/Non passing/No connection using code (In process flow).
Message 8 of 26
moehlmann_fe
Yes, that is possible. The connection type is stored as a node value in the Network Nodes attributes. (1 - No connection, 2 - passing, 3 - non-passing)
Changing between passing/non-passing seems to work right away (the next traveler that enters the path will behave accordingly). If you switch from No connection to one of the other nodes, you have to run the command "optimizenetwork()" so the routing table is recalculated.
pathtype-swap.fsm
Message 9 of 26
diweashish94
This is exactly what I needed. Thank you @Felix Möhlmann
Message 10 of 26
Jeanette_Fullmer
Hi @Ashish,
Thank you for contributing to our community! We couldn't identify a maintained license or subscription linked to your account.
You may need to update your profile information to identify yourself as a license owner or their associate. Check out our article for how to ensure you receive timely support. If you update your profile comment back to let us know - we'll adjust the priority of your post accordingly.
If your current license is expired, please contact your local distributor to renew.
Message 11 of 26
diweashish94
What if while swapping the path, task executers are in between the intersection or gets stuck in no connection path
Pathswap_Trucks.fsm.
Message 12 of 26
moehlmann_fe
I guess a simple workaround would be to just not close the connections out of paths section. So any traveler already in the section can still leave but no new ones will enter.
pathswap-trucks(1).fsm
Message 13 of 26
diweashish94
Hi @Felix Möhlmann
In the model attached even after using Non passing connection type, the AGV's are colliding with each other.
Is it a bug or do I need to make changes in the logic.Nonpassing_Collision.fsm
Message 14 of 26
moehlmann_fe
AGVs on a network node are by default not counted for the passing rule. You have to set them to "...block space on networks" to make following travelers stop.
Message 15 of 26
diweashish94
It is working fine.
Thank you.
Message 16 of 26
diweashish94
Hi @Felix Möhlmann
I tried to implement the same logic into the model I've attached, but it didn't work.
As I can see that the event is not getting trigger when Truck moves from Point A to Point B.
Would you please help me with it. And please let me know where I'm making mistake.
Thank you
NN_Avoid_Collision_At_Intersection.fsm
Message 17 of 26
moehlmann_fe
The logic needs to know whether the traveler is moving towards the intersection of away from it when arriving at the network nodes.
In the original model I adjusted the paths so that the first edge is always the one moving into the intersection. As such the source could be set to only trigger if the "toEdge" parameter is equal to 1.
This doesn't work anymore since there are sometimes two paths that lead into the intersection. So you will need to assign the "toEdge" to a label and use if-conditions to decide whether the token needs to continue down and possibly stop the traveler or if it can be discarded.
nn-avoid-collision-at-intersection_1.fsm
Message 18 of 26
diweashish94
I have made the required changes in my code, but at 145sec two of the tokens are getting stuck at "Wait for Event activity". And I'm not able to figure it out the reason behind it.
nn-avoid-collision-at-intersection-1.fsm
Message 19 of 26
moehlmann_fe
It's the same issue. The token currently waits until a traveler passes one of the intersection nodes with a "toEdge" of 2. Now the toEdge would be dependent on which node they will exit the intersection through.
If you know which NN the traveler will arrive at, you don't need the toEdge. You'd assign that NN to a label and only listen for arrival events where the traveler matches for that NN.
Message 20 of 26
diweashish94
So don't we have to use the wait for event activity?
