Possibility of FlexSim crashing
ozawa_shinya
ozawa_shinya
[ FlexSim 22.0.16 ]
FlexSim may crash in the middle of running a large model on my PC. However, this phenomenon is not reproducible.
After running a large model on my PC, FlexSim's CPU usage stays above 20% until it crashes. My PC has 4 cores, so that core is always above 80% utilization.
I'm using 'Fast Forward' to run, so I don't think the graphics affect it. The memory seems to be relatively free, but the CPU load seems to be high. I suspect the CPU is underpowered, is it possible that FlexSim crashes because the CPU usage is too high?
Thanks in advance.
jason_lightfoot_adsk
Only if you exceed the thermal limit for some reason - most CPUs throttle back the clock speed to manage this. You'd expect each FlexSim vcore to be 80-100% utilized while running.
Does your model repeat correctly each time you run it? Does it run to completion if you are not fast forwarding?
julie_weller
Hi @Shinya O, was Jason Lightfoot's answer helpful? If so, please click the "Accept" button at the bottom of their answer. Or if you still have questions, add a comment and we'll continue the conversation.
If we haven't heard back from you within 3 business days we'll auto-accept an answer, but you can always comment back to reopen your question.
