Popup window bye code
viktor_tt
viktor_tt
[ FlexSim 18.0.1 ]
Hello!
In my simulation, I've implemented an error message system
(with msg() command), which create a popup message if one of my for() cycles do not found the correct value.
How can I write a codeline which automatically open the window which contain this code what printed the error message earlier?
If it's not so clear:
for() running --> there is no corrent value --> popup a message dialog --> I close the dialog --> automatically open the code window which contain the for() cycle.
mischa_spelt
If you write the debug() command in your code, it will act like a manual breakpoint. So your code could be something like
for(...) {
  checkValue();
  if(!value) {
    if(msg("No value", "There is no value. Do you want to debug the code?", 4)) {
      debug();
