Please help with "Exception" Error
jim_montgomery
jim_montgomery
[ FlexSim HC 5.0.12 ]
crmh-ed-ver-8x.fsmCould someone please help me to understand the reason I am getting the following error message every time I attempt to save my model, and what can be done to fix it?
exception: Exception Caught in Navigator::onReset() object: /DefaultNavigator
exception: Exception Caught in ObjectFunction230__project_library_FlexSimEventHandler_behaviour_eventfunctions_OnReset object: /DefaultNavigator class: /DefaultNavigator
sam_stubbsYXX86
I'm not sure what was causing the exception to fire, something was just causing Default Navigator to not respond properly. I seemed to fix the issue by simply deleting the navigator. (I went into the model tree and found the default navigator and deleted it, FlexSim then creates a new one when it's called.) That seemed to fix the exception. If it happens again, let us know. (Also make double sure to back up your file before you delete it, just in case.)
I'll reattach the model here: 1673-crmh-ed-ver-8x.fsm
jim_montgomery
Thanks, Sam. It works fine now.
