Pickup batch of totes from several different racks
magdalena_b3
magdalena_b3
[ FlexSim 22.0.0 ]
Hi everyone, I have a problem with picking batach (4 ) of totes from several racks using list and deliver to one queue.
I asked for somethig simmilar, but that was different case Unloading Batch.
In this case I have a RackList with all of the totes in Warehouse. Totes have some lablels ex. ID number. In table Mrowa_1_tab (order list) is list with ID I need to deliver to one queue.
I used pull from List where I compere ID of tote from the warehous and ID from the Mrowka_1_tab, to pull only the totes there are in order list.1654078973865.pngUsing the previous solutions it doesn't work.
Here is my model
ex_racks_batch3.fsm
jason_lightfoot_adsk
What doesn't work? Your tokens do pull things off the list. But you don't need the subflow to pull 4 items - just put 4 in the quantity to be pulled and instead of using AssignTo - select InsertAtFront of for the pulled array.
Having done this you will see that you don't have 4 things on the list with that index number so it will stop.
magdalena_b3
Thanks @Jason Lightfoot for your answer ,but I'm afraid we misunderstood.
Let's chceck my model attached.
When I delete query form PullFormList it works. But it pull all of the totes form the RackList.
The thing I would like to do is to Pull only the totes which are in the order list - Table "Mrowka_1_tab" .I need to compere these two values (ID in the table and ID in RackList)
ex_racks_batch4.fsm
When you call runSubflow and create 4 tokens they all have the same value for "Indeks" since they are copied from the token with tokenIndex1. So you can 4 tokens trying to pull items with 2 off the list.
Why are you creating 7 tokens (the number of rows in the Parameters_Tab table)?
You could create the number of picks in Mrowka_1_tab and batch them in groups of 4 aggregating the ID number into an IDs array. I show this in the attached model. You need to specify the token.Unload label somewhere.
ex-racks-batch4_jl.fsm
magdalena_b3
Thank You for your help! It works 🙂
PS: I sampled by mistake the Parameters_Tab to create tokens...
Ah - okay - an easy mistake to make.
