Picking items from a conveyor using a robot
BPassos01
BPassos01
[ FlexSim 22.0.16 ]
Hello there!
I'm kind of new to FlexSim and recently building a task where an item needs to be picked up from a conveyor using a robot.
At first, thought about using a decision point and make the robot pick the item as soon as it crosses the point, but i dont really know how to do it and even if this is the right solution. Theoretically, the box should be removed right in the spot that is marked with the decision point.
Can anyone give me a little help?
Thanks in advance! Best of regards
FelixMoehlmann
The simplest method would be to draw an A-connection from the conveyor to where the items should be moved and activate the "Use Transport" option in the Exit Transfer.
You can also build logic in Process Flow that reacts to an item arriving at the Decision Point and tells the robot to move it.
If you haven't worked with Process Flow before I would suggest you look into the relevant tutorials.
gustavo_teodoroD8NVF
Completing the above answer, upon reaching the decision point, you can use the "Send Item" trigger on "Arrival" and send the item to the "Exit Transfer". Upon reaching the "Exit Transfer", the robot will execute the movement. Attached is an example and a screenshot of the sending logic.
FX_Picking_Example.fsm
BPassos01
Gustavo, couldn't open the example archive you sent due to FlexSim's version (I'm using 22.0.16). One more thing, is there any difference in the funcionality if the conveyor is displayed in a circle, without having a proper end? (just like the image)1709302217182.png
For some reason, the above solution didn't solve the problem 😕
Hello Breno, it works perfectly in a conveyor displayed in a circle. By the way, I have attached an example in FelxSim version 2022.
FX_PickingExample.fsm
