Performance Measure Changed After Using Export Button
nicholas_d
nicholas_d
I am using tracked variables as performance measures in the experimenter. The experimenter works fine if I do not export the results to a .csv but once I click the drop-down button to export, the tracked variables are turned into Standard Performance Measures and lose their tracking information. The experimenter then returns zero for all PFMs that were changed. Is there a reason for this change to the performance measures? Please see the screenshots attached.
JordanLJohnson
This is a bug. I'll make sure it gets on the dev list.
Jordan Johnson
Principal Software Engineer
