How to reference values in an array in a table cell
patrickABAWF
patrickABAWF
[ FlexSim 20.0.2 ]
I have global tables for which the cell format is array so that I can put many values in each cell.
What is the correct syntax to reference a specific value in an array in a cell?
For exemple, I reference the cell with Table("Interventions")[5] but that gives me the whole cell content. I just want to reference one value in the array in the cell.
By default all arrays in every cell have the same name: Array[1]
Matthew_Gillespie
Here are a few ways you could do it:
return Table("Interventions")[5].as(Array)[2];
Array array = Table("Interventions")[5];
return array[2];
return Table("Interventions").cell(i, 5).value[2];
Matthew Gillespie
FlexSim Software Developer
patrickABAWF
When I write this (with an index of 1) it returns the whole array.
If I put an index greater than 1, I get "Array index out of bounds".
And all my arrays have a length of at least 3.
Matthew_Gillespie
Do you have an array of length 3 inside another array of length 1?
You said "By default all arrays in every cell have the same name: Array[1]". That looks like you only have length 1 arrays in the table.
Maybe you should attach the model?
Matthew Gillespie
Jacob_Gillespie
Maybe you are mistaken in how you think the array is set up?
It sounds like you have an array inside an array.
patrickABAWF
All methods return the same problem. Might be the way the array is setup in the table.arrays.fsm
Here is my simplified model. The code is in the "Find room" box.
Matthew_Gillespie
All the arrays in this model are length 1. They have a single string inside of them. For example, cell 1,5 has the string
3,4,5,6,7
You need to double click on the arrays so that it opens a new table editor and then add 5 rows and put a different number in each row. Then the table will look like this:
Array[5]: {3, 4, 5, 6, 7}
instead of this:
Array[1]: {3,4,5,6,7}
Or just use code to set the cells:
Table("Interventions")[1][5] = [3,4,5,6,7];
Matthew Gillespie
