Patient takes an elevator to a floor with a negative Z
ClairAu
ClairAu
[ FlexSim 22.0.3 ]
Open the attached model Patient + Elevator v1.fsm.
The patient takes the elevator down to the floor spot:
Open the attached model Patient + Elevator v2.fsm.
The patient walks towards the elevator, but the elevator does not go up. The patient walks down to the elevator.
Here is the difference between these 2 models:
  • version 1: the floors are at z = 5m and z = 0m
  • version 2: the floors are at z = 0m and z = -5m
Should there be a fix ?
Or is it forbidden to use elevators with floors at negative Z locations ?
In the properties of an A* grid, typing a negative value in the Z position field is not allowed, the value is set back to 0:
However, if you set the 3D view Grid Z field at a negative value you can actually create an A* grid at a negative Z location:
So having an A* grid at a negative Z seems like "half forbidden / half allowed".
@Matthew Gillespie
Matthew_Gillespie
There seem to be some assumptions in the code that A* grids would never be at a negative Z height. I'll add this to the dev list to discuss allowing negative z heights. For now though, I would stick to positive Z heights for the grids.
Matthew Gillespie
FlexSim Software Developer
ClairAu
Thanks Matthew for the new update in 23.0:
Allowed A* grids Z height to be negative.
